Re: Primer?
I am guessing that you are looking at an epoxy based barrier coat. It will need to be sanded off. That is a lot of work. Additionally, the gelcoat was probably lightly sanded to scuff up the surface before it was applied. <br /><br />While I agree with JB that a trailered boat does not need bottom paint, in your case (I currently have the same situation), I think you have two choices:<br /><br />1) Re-apply a bottom paint. <br /><br />2) Paint(with a top-side paint) or re-gelcoat the hull bottom to get it to look good. <br /><br />For my bottom paint, I am using a multi-season ablative. I am also only doing it because the boat was previously bottom painted and I don't have the energy to remove it. The good thing is that the black bottom paint is complimented by black accents in other place on the boat and it doesn't look too horrible.
