Transom Protection
Norman Buus
On my 1988 Sunbird I/O, they just cut through the transom for the outdrive, and apparently did nothing to protect the raw plywood edge. Plywood may be pressure treated and is in good shape. Should I do something to protect the exposed plywood?
Re: Transom Protection
If you have the driveline Out of it Now,+ Good access to it,.... Sure,.. Seal it Up.......<br /><br />Sunbirds are Entry Level boats,.... I Really Doubt that's a P/T Plywood Transom........
THE BEEF
Might want to give it a couple good coats of West systems. What do you think Bondo?<br />Beef :D
Norman Buus
Thanks guys. I haven't figured out what yet, but I'll coat it with something. I may have some urathane paint.
BillP
Sunbird may have used Greenwood pt ply in their boats. Many entry level boats still use it.
jnewtonsem
If you've got some time try CEPS from The Rot Doctor at www.rotdoctor.com Its a very thin penertating epoxy that seeps into wood and protects. You can then seal it up with urathane or something else. <br /><br />A transom is something you don't can't overprotect. I've had 2 OB's and an I/O had to replace the transom in all of them.
