66Holiday924
Thread starter- Joined
- Aug 21, 2017
- 634
The boat has ribs running port to starboard. The stringers run across the top of the ribs elevating them about an inch or so. I'm running sheet plastic across the ribs also. That's going to create about a 1 inch cavity for water in the bilge to move. You pour the foam on top of the sheet plastic. It might press some areas of the plastic down, but the plastic is rigid enough that there is going to be a pretty effective in creating the cavity I want. Additionally the forward cowl is meant to naturally ventilate the bilge and engine compartment. I'm going to run the bilge duct hose below the sheet plastic so air can circulate through the bilge and engine compartment and escape through the aft cowl.
