Re: Trolling motor battery setup
No, youre not confused. You understand the idea
the deep cycle batteries are connected in series to support the 24vs needed for your trolling motor. Do NOT connect this 24v-system to your 12v-starting battery system. Why in the last paragraph below.<br /><br />The On/Off switch is used to switch the 24v-current on or off to the trolling motor. That is all. It never sees 12v anything.<br /><br />The 1/2/All/Off selects the source of 12v-current used to start the engine and switches the source selection on/off. You connect your 12v-starting battery to position 1 on this switch. To start your engine, turn the selector dial to position 1 and go. Leaving it in position 1 allows your engines alternator to charge the starting battery while running.<br /><br />Optionally, you can add a second (backup) 12v-source to position 2 of the 1/2/All/Off switch. Should your starting battery be depleted, you turn the switch dial to position 2 and start the engine. You do not have a backup 12v-source so switch position 2 is useless to you right now. The All position bridges 12v-source 1 and 12v-source 2. This position allows the combined amps from both 12v-sources in parallel to be available in the event of a difficult start. There are several reasons why you should not leave the switch in the All position after starting the engine but that is beyond the scope of this discussion.<br /><br />For your installation:<br /><br />1- The On/Off switch is used strictly for the 24v-system.<br />2- The 1/2/All/Off switch uses only position 1 for the 12v-starting system.<br />3- Option: in the future, you can add an additional 12v-starting battery to the 1/2/All/Off switch in position 2.<br /><br />When you connect the battery cables, check the studs on the back of the switches. There should be no corrosion whatsoever and the studs should be fully intact. If the cable lugs (the end connector with the hole in it) were ever connected loose, arcing may have occurred and the switch stud would look like it was eaten away. If so, replace the switch.<br /><br />Be sure to tighten the cable lugs against the switch studs very securely. There should be a lock washer that needs to be the last thing added, after the cable lug and before the nut is placed and tightened.<br /><br />If you connect the 24v-trolling system and the 12v-starting system to the 1/2/All/Off switch you have a disaster waiting to happen. Turning the dial to the All position would bridge the 24v-system and the 12v-system, doubling the voltage going into the 12v-starting battery. This would cause an instant boiling of the battery soup and arcing between the lead plates inside the 12v-battery case. That part of the battery soup that is water (H2O) is electrically excited and the covalent bonding of the molecules is broken
oxygen and hydrogen gases instantly start forming inside the battery case faster than they can escape. Depending on the condition of the battery, the time it takes for the arcing inside the case to ignite the hydrogen gas can be measured in milliseconds to a few seconds. In a best-case scenario, the battery caps blow off and sulfuric acid is sprayed out the holes. At its worst, the battery case ruptures and the acid is blasted everywhere.
