Re: switch transom to bow "motorguide troling motor"
I suggest you measure the shaft or hold the trolling motor next to the deck to see if the shaft is long enough to keep the prop in the water. Most transom mounts are too short. There is a fix for a short shaft but that can be along trial and error story or a trip to a repair facility.<br /><br />Reversing the head is easy. Just remove the 4 underside screws that hold the top of the head on. Remove the top and you will see a screw that holds the shaft to the head. Remove that screw and gently turn the head 180 degrees. Now you have a bow mount hand control TC.<br /><br />You have to figure out how to get a bow mount that will fit the shaft diameter or figure out a collar to fit on the shaft so your bow mount will hold it.<br /><br />What ever you do, if you unplug the wires, make an exact diagram of which wire connects to which plug at the top of the head.
