Quick question about GPS with built in antenna...
philtheskipper
Can a fixed mount GPS with a built in antenna be used when mounted under the windshield? Does glass block gps signal? How about a canvas top?<br /><br />I'm looking at a used Garmin 126 to replace my Garmin 120. The antenna for my old unit quit on me and I can pick up the 126 for the same price as a new antenna for the old one. <br /><br /> http://www.garmin.com/products/gps126/
JoeW
Re: Quick question about GPS with built in antenna...
Phil,<br />I've got a handheld eMap GPS. I use it in my truck all of the time. Glass doesn't seem to obstruct the signal, but if I put it in the glove box or in the center console it doesn't work well. My guess is that it would be fine mounted on a boat dash, even under a canvas top.<br />-Joe
Boatist
Phil<br />I have a GPSMAP 76 and it works just fine in the car even down on the seat. Also works fine in my boat up on the dash behind the window with a canvas top. I have not put in any mount so when real rough I sometimes put it on my seat between my legs and it even works there most of the time but does some times loose signal at that location.
JB
Hi, Phil.<br /><br />I use my Garmin 162 in my truck all the time. The antenna can't see through the roof, but it gets plenty of satellites through the glass. I mount it on the dash.<br /><br />No worries about seeing through plexiglass.<br /><br />Go for it and good luck. :)
18rabbit
Any metal, solid or wire mesh, between the antenna and the satellite can snatch the signal and take it to ground before it reaches your GPS unit. Non-conductive material (glass, plastic, fiberglass, cloth/canvas, a small child) generally isn’t an issue. In the window, your biggest problem will likely be the heat from being directly in the sun.
Paul Moir
I remember being conductive when I was a small child. :D
18rabbit
Paul, but not when thrown over the antenna. :D
FISHROT
I have a 126 mounted on the dash of a center console below the glass and grabrail and I have never had a problem receiving a signal.
philtheskipper
Thanks for all the info. I ended up getting a used Garmin GPS 128. Same thing as the 126 but has an external antenna.
