Re: wiring diagram for OMC tach
beach,<br />Black is your ground connect to terminal marked "GND"<br />Purple wire is your accessory or hot wire, usually comes off the ignition switch, connect to terminal marked "+12V". If your tach illuminates, you may need to make a short jumper from the +12v terminal to the light bulb terminal, depending on your tach.<br />White/gray is usually the tach wire from the engine. Connect to the "Pul" or pulse terminal.<br />JD
