Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Thread starter- Joined
- Nov 23, 2020
- 883
Hello everyone! Been hanging out in the starcraft rebuild forum with the mob for most of the last year. Not sure if I put the cart before the horse, but the boats looking good and my motor is having issues….
Link to boat rebuild here: https://forums.iboats.com/threads/1979-starcraft-16’-ss-refresh.740894/
Lets introduce the twins first!
On the boat currently is a 1983 J75TLCTE. She is in rough shape. Back up to the previous owners…. got her a year and a half ago from a friend who drilled two holes in the side of the housing to get to the bolts that hold on the exhaust manifold. She got water into the #3 cylinder and he replaced all those gaskets. #3 cylinder has scaring. Prior to that maintenance is unknown and probably poor. The gas tank she came with was an old rusty 18g tank with a hole. Needless to say her carbs are bad. Also, her threads were stripped on the cylinder head cover for the spark plugs. When I got her, I ordered a full gasket kit for the top and bottom. I swapped the other motors’s cylinder head cover onto her since the spark plugs holes were toast, and i butchered rethreading them…. Replaced all seals in the lower unit except the prop shaft seal (now leaking), put in a new water impeller kit, and changed the lower fluid. So… the good news - the 75tlc does run. She has a lot of trouble starting on the water, more now than when i got her. A guy yesterday said my carbs have a flat spot when firing. On the muffs she fires quick and can idle all day (roughly), she has a little shake. Im also at 4000’ at home and boat at 5000’ elevation. After she runs on the water for a bit though, Im good the rest of the day when shes warm. Runs great at WOT where i normally keep it, unless Im trolling where she will idle rough but all day long (last year at least). Recap: Needs carb rebuild, prop shaft seal replaced. Fuel system is completely new - new fuel/oil, lines, tank, and a water/fuel separator. I use semi-synthetic oil and she seems to like it, smokes a lot less, runs smoother.
Next up is the “twin” sister - a 1978 75 Johnson Stinger - J75ELR78C. This motor was found barely hanging on to the back of the 1968 SS minnow from gilligans island (not literally). A lady was giving away her husbands forgotten project - it was an eyesore in a nice neighborhood in the nevada desert. I drove 2 hours from the CA sierras to the NV desert and picked up the boat to get the motor. Its lower prop shaft had sunk into the dirt it looks like and leaked all the lower fluid out. The rubber inside the cowl covering wires etc looks good, but the cowl seal and any rubber outside was destroyed by the desert sun/heat. I borrowed the cylinder head cover off of it for the other motor so I can see inside the cylinders. They are clean and smooth so thats good news. Also there is zero gas/oil/debris under the cowl. Someone took good care of her until she was put away, and sat outside for at least 3 years until I got her. Now she is sitting on a motor stand in my garage, waiting to be brought back to her former glory.
Now, my thoughts on what to do…. This is the story of 2 motors - the ugly duckling (tlc) and the stinger (elr). Ideally, Id like to get the ugly duckling running enough to keep me on the water while I rebuild the stinger top to bottom. Then swap em, run the stinger while I rebuild the ugly duckling top to bottom.
So where do I start and what tools do I need? Is my fix up, rebuild, swap, rebuild plan smart or do we need more info? I admit that Im not a great mechanic so all the input is appreciated and welcomed. From reading previous threads I know @racerone is going to say “what are your compression numbers?” Well, I do not know…. But i have a tester that just needs the right fitting to check them.
For the ugly duckling, which Ill refer to as UD from now on, current plan is to rebuild the carbs, and replace the prop shaft seal, as well as check compression.
Open to suggestions. Id like to get a manual too for these motors. I believe i need a special tool to help with the removing the prop shaft too. Again, please help!! Thanks everyone. Looking forward to the roller coaster ride of working on old boat motors. Hoping for 2 good runners in the end, but would be happy if that stinger runs great and the UD ends up as a parts motor.
Stinger pics first. Next post UD pics.
