tkcenterline
- Joined
- Jul 19, 2004
- 23
I have a 91 evinrude 57 trust 12/24 trolling motor. When the dealer wired it, he had the two trolling motor batteries and the starter battery in the rear of the boat. It was to much weight. I am moving the trolling motor batteries to the front. The dealer had a 120 volt 20 amp swich at the console up positon was for 24 volt and down was for 12 volt charging. The switch has been to light for the amp. I have to replace it every year because it gets toasted. I was usng two battery chargers to charge both the batteries. I have to put the switch to 12 volt during the charging. Is there a better way to wirer a 12/24 volt system. Maybe use a relay (40-60 amp)in lieu of this 20 amp switch. The trolling motor will work on 12/24. Do I even need a switch/relay. I know enought to get me into trouble. Help I also bought a new 2 bank duel pro battery charger. I want to wire a new system using my trolling motor and new battery charger. Maybe some one could e mail me a diagram?? Thank you
