deep cycle
tori0701
I just got a deep cycle battery for my trolling motor can I use it with my other components like my lights, horn and my bilge pump.
JB
Re: deep cycle
Yep.<br /><br />Good luck. :)
tori0701
Re: deep cycle
What would be the procedure on charging it after I use it.
Paul Moir
Re: deep cycle
Every time you use it, using an automatic electronic charger.<br />The less time the battery spends not fully charge, the longer it will last. Try not to discharge it past a 50% charge (not 6 volts!) and it will last a very long time.
wilkin250r
Re: deep cycle
If you need to go out and buy a battery charger, spend a little time researching and a few more bucks and get a decent charger either dedicated to deep-cycle recharging, or with a deep-cycle setting.
