Cuskmaster
Thread starter- Joined
- Jul 19, 2004
- 9
First of all, let me say that these forums are great! I had a months- long problem (thanks to some bad advice from a dealer) solved in a couple of evenings and help from the folks who troll these sites. O.K.- now my question- I have a Perko battery selector (off/one/all/two) and 2 different batts- one troll, one start. I plan to connect my starter hot wire AND a wire coming from a bus with all my electronics (bilge,lights, ff, d-riggers,12V troller, etc,)to the common terminal on the perko, and ground all negs. Is this O.K.as long as I never switch to OFF while motor is running? The perko has a "make before break" so I thought I could use the altenator to charge my trolling batt after starting with my starting batt. If this is O.K. to do, then can I put the pos lead of my charger/ maintainer on the common post of the switch and charge the batteries at home one at a time, depending on the position of the battery switch? I know you guys have visited this type of question a ton of times, but I am still, regretfully, in the dark! Thanks in advance for any help that's offered!
