Re: Battery storage
There is not currently a strong reason for avoiding contact of a battery with a concrete floor. The battery's contact with the concrete should not create a problem with the material in today' s batteries. If the battery is not clean, but has a surface layer of acid or grime which is conductive, the battery can be expected to self-discharge more rapidly than if it was clean and dry. Many years ago, the batteries were constructed with a wooden case around a glass jar with the battery in it. Any moisture on the floor could cause the wood to swell and possibly fracture the glass, causing it to leak. Shortly after the introduction of "Hard Rubber" containers, which were somewhat porous and of a less than ideal design, there was a chance of current to be conducted through the container of a high carbon content if the moist concrete floor permitted the current to find an electrical ground. These are two of the older reasons for not storing batteries on a concrete floor. There is no reference to avoiding storage on concrete floors in the Battery Service Manual published by the BCI.
