Re: Battery charging
Maybe, but most cheap battery chargers do not have any output filtering. The only discharge path would have to include the bridge rectifier. If you have a highly regulated charger then you have the regulator circuit and need the isolation diode. This said, I always disconnect my charger.<br /><br />Your method is a good way to determine if a problem exists. I would use a miiliammeter and a series connection, but I like your simple approach. Much less room for error
