Re: 36# MinnKota - Clicking
J,<br /><br />I have a slightly differing opinion. It sounds like one of two things. <br /><br />1) The brushes are worn down so the brush harness is rubbing against the housing.<br /><br />Solution -open it up and take out the brushes and replace with new ones and she will run like new. $ 10.00 to $15.00 fosters in La.<br /><br /><br />2) If you hit somthing, it could be that the outer magnet cracked and is rubbing. You can get a new housing for about $20 to 25.<br /><br /><br />Just my thoughts. Before I went out and bought a new one, i would tear it down (not Hard) and find out what the problem is.<br /><br />The only bearing is usually a single ball at the end of the shaft. just bube it a little. and the brass bushings are almost contiunous duty so they too shouldn't be bad. But who knows ...could be.<br /><br />Hope this helps<br /><br />kid
