24 volt diagram
chad2727
i need a diagram on how to wire two 12 volt batteries together to achieve 24 volts
Realgun
Re: 24 volt diagram
This be new Positive <br />+battery- (Wire this together) + battery- <br />This be new negative<br /><br />(wire this together)<---This represents a big wire!<br /><br />Think about how you put batteries in a flashlight. You put the flat part first they you put the flat part of the next battery in. The flat part is negative the bump is positive<br /><br />=> {+ -] {+ -] {+ -] {+ -] 4 batteries in a flashlight is 6 volts. 1.5Vx4batteries
