Re: Crimp large wire
solder is a great asset .. not nary a fear.. if'n you know how..<br /><br />big job = big heat..small job = small heat.<br /><br />this job is big heat i.e. torch.. <br /><br />crimp then apply torch heat<br /><br /> ( the tip of point of the inside blue colored flame,, )<br /><br />( see,, there's the overall flame.. but the hottest part of the flame is the point of the tip of the inside the flame's body )<br /><br /> to the bolt hole part of lug.. <br /><br />after a short while,, touch solder to the space where the bare wire enters the lug..<br /><br />if after a 1/2 second an no flow,,continue heat untill you touch again an the solder flows.. <br /><br />remove heat an let cool..
