Realgun
Thread starter- Joined
- Jul 31, 2003
- 2,484
I need to set up a single switch to run Nav/Anchor lights.<br />I have a double pole double throw switch already.<br />I need to make 2 wires go to 1 wire.<br /><br />I want the anchor light on in either position and the nav on in 1.<br /><br />The nav goes to 1 circuit but I need the anchor to be on in 2 positions. There is no jumper for this so how can I use 2 of the 1/4 blades connectors to 1 wire?<br /><br />Basically from the switch there are two blades that I need to connect to. I only need 1 wire to the bulb. And the end of the wire to both poles. According to USCG how is this done?
