Basic Duel cycle Battery Question..
dd716ted
I have just replaced the original starting battery that came with my boat with a new Dual Cycle Battery.. (size 24).. Question.. This battery has both the conventional lead battery posts and a set of threaded battery posts. Are both of the (+) posts and the (-) posts the same or does each set perform a different function? Does it matter which ones I connect the motor and accessories leads to? Thank you
Boatist
Re: Basic Duel cycle Battery Question..
Yes the + post and the + thread go to the same place. In just lets you use either the old post type connection or the newer side thread type connection or both. Same with the negitive connections.
