Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
mailman1...there isn't really any one size fits all, it depends on the current draw of the device, the length of the run, etc. I suspect you could use 16ga for some of those but if your buying wire in bulk then you might want to go with the 14 to be on the safe side.
16 GA will work fine as all those components are relatively low current draw. I would get a wiring diagram for the boat and try to keep the stock colors for ease of troubleshooting later.<br />Later,<br />
It reall depends on current draw and how far you got to get the wire to and from.<br /><br />If the lights draw say 3 amp. And ther are 14 feet to and 14 from the ligh you can use 16 guage however two more feet will reqire 14 guage. <br />To be real safe you can use 14 guage for them all (I don't know the current draw or length of device to power)<br /><br />Personally I would rather be safe then sorry and die due to not having say a radio when I needed it. Due to not wiring correctly and then dying cause the boat burned to the waterline and I was say 10 miles from shore.
