I ordered and rec'd my OMC (push to choke) replacement ignition switch.<br /><br />Is there an online diagram that shows the colors of the wires for the ignition switch somewhere that I can study?<br /><br />I removed the wires from my switch and now need to connect the last wire, which is supposedly the second MAGNETO wire, which it *says* to:<br /><br />attach to the cable from the *electrical system ground to the threaded insert M terminal.*<br /><br />I notice i have two purple wires with white stripes, and in following them back, it appears the choke is a purple / white also. The last wire left over needing termination is a purple/white, thus my need to see a wiring diagram.<br /><br />TIA!!
