Had the bellows, lower shift cable and gimble bearing replaced! Now for some recent history! Last fall, I removed the lower Alpha 1 gen 1 unit, but forgot to put the shift lever into forward! Possible dumb thing #1?? Drained the lower unit, but did not refill. Possible dumb thing #2?? The mercruiser 260 hp shifted fine when taken out last fall but now it gets hung up and is difficult to get into/outta gear without jiggling and getting into neutral is a toss up! When the mechanic did his work I told him about the shifter not being in forward and no lower unit oil! He did refill the lower unit! I tried adjusting the lower shift cable with no success. Could letting the unit sit all winter empty have a negative effect! Does this sound like cable adjustment gone wrong or potential lower unit problems? Thanks!
