boat leanning
REEL TIME
I have a 2240 roblao cuddy and it has a 2001 200 hp optimax. The boat has a tendsey to lean at high speed about 27 nmph one side to an other it has trim tabs .
Tufan
Re: boat leanning
is it leaning just a little bit or very noticible? I think you may want to check Trim Tabs connection arms. Are they adjustable or one of those smart tabs?
Jdeagro
iboats.com Partner
Re: boat leanning
Reel Time,<br /><br />The trim tabs should correct any leaning. If they are helm controlled they you simply adjust them and If they are Smart Tabs they will automatically adjust. If the boat has a severe tendency to list to port ( Torque List) then the Smart Tabs can be specifically adjsuted to compensate.<br /><br />If you are also using a hydrofoil on the out drive then this should be removed.
