Re: Cranking Battery -Which one is it?
There are a couple of very important things you should know about using dual batteries and a switch. Knowing this will help prevent problems with your system. These apply to outboards for sure, and likely to stern drives as well. <br /><br />1) DO NOT operate the motor with the switch in the "OFF" position, as this will likley destroy your alternator and charging circuit($$$).<br /><br />2) Know your equipment. (a) Find the motor cranking amp requirement, as well as the battery spec's and make sure they are compatible. (b) Find the motor's alternator maximum output (amps). (c) Does the switch have "make or break" design? Most modern switches do, but check with the manufacture or a local marine dealer to be sure. This allows the switch, for example, to momentarily make contact to battery 2 before breaking the contact to battery 1, and vice versa. This design prevents two things. (a) The alternator output from having "nowhere to go", and destroying the alternator, and (b) Power is not lost to your users such as electronics, radios, switch circuits, lights, etc. Depending on the manufacture, these warnings may be on the face of the switch.<br /><br />3) Outboard alternators, especially smaller HP engines, typically have a much smaller capacity than their automobile counterparts, which can be up to 100 amps or more. This is because boats generally do not have all the demands (computers, power windows, locks, wipers, headlights, tailights, A/C & heater fans, etc) that an automobile has. As such, don't expect low batteries to be fully charged in few short minutes at idle speed. It may take 30 minutes or even hours at higher speeds to fully recharge the batteries.<br /><br />Think of connecting a typical home charger to a auto battery and seeing it draw a 8-10 amps max charge rate, even overnight to 24 hours for a highly drained battery. If your boat has an amp meter, this will indicate the charging rate of the battery connected to the circuit with the switch (1, 2, all). Having a volt meter will not tell the whole story.<br /><br />Hope this helps!
