what color?<br /><br />Originally posted by JohnRuff:<br /> Does anyone agree with me? Whenever I make an electrical connection no matter if it is crimped or soldered, I apply fingernail polish to the connection. An old time ham radio operator once told me that fingernail polish is almost pure enemal and will protect the connection forever no matter what.
I just re-wired my 35 year old Slickcraft. This boat was built by the same MFG that builds Tiara and prior to Slickers (the founder of Tiara) leaving to form his own boat MFG, he was a leader with ChrisCraft. I would consider this boat though old, an upper tier manufactured boat. It has well stood the test of time with it's second engine with over 1,300 hours behind her. When I did the rewire, none of the original wiring that was removed was tinned. I did however use tinned wire to replace the re-wired systems though. The price difference was not enough to justify not using it. <br /> One thing I considered in my choice is that every single electronics accessory or electrical addition to my boat be it a Speed & Temp, Fishfinder, GPS whatever uses tinned wire. Now I figure 35 years ago it wasn't used. Does this make tinned wire a bad choice? I doubt it. <br /> As far as soldering? The only connections I soldered after crimping were larger than 10 ga. ie. Battery Terminals.Originally posted by Peter_in_Maine:<br /> "OEM wiring is not tinned wire, that should tell you something."<br /><br />Actually, the upper tier boat manufacturers do use tinned wire, That should tell you something!
At Honeywell which is now Alient Tech we used these solder sleeves on all shielded cable. They work great however the wire has to be teflon so that the high heat required to melt the solder would not melt the wire insulation. Also they required a special fitting for a heat gun so the heat would be concentrated on the bead of solder. My only concern with these conncetions is it is impossible to remove the flux from the connections because of the sleeving on it.What do all you guys think about Raychem Solder Sleeves? They have solder in them that melts when you shrink the sleeving which seals the joint. I recently ran across these beauties when installing stereo in my car. They work great!
