First boats seem to be a money pit.<br /><br />Here is my problem and I hope one of you guys can lend a hand.<br /><br />My boat has the 1989 260 (350) alpha drive.<br />I have noticed lately my gauges (all) go blank. Tach, oil press, trim, and engine temp (voltage meter goes to 10volts when this happens). I have checked all the grounds and they look good and test good. Last week I noticed all gauges go to zero (no Power). I turned the ignition on and off with no luck. Everything else runs fine though. The lights, bilge, trim, horn, starter, and blower. One my way back in, all just started working. I have looked at the terminal board several times and all looks good. I have noticed the ignition switch has three wires, which a purple one goes to all the gauges. Is it possible for the switch to go bad only on the purple wire leg?
