90 Hp Johnson, Wiring from solenoid box to key
kdaviseod
What are the lights for, one has an on sign with a push button spring and one is a clear lense with a bulb on it. Trying to rewire after reconditioning the boat. Kind of stuck figuring this out. Wiring diagram for the rest of the wiring harness from box to key appreciated.
OBJ
Re: 90 Hp Johnson, Wiring from solenoid box to key
Need a year or model number (preferably a model number) for the right diagram KD. The older engines used to use a couple lights. One to show the ignition was on and the other to indicate engine overheat.
