ignition switch wiring codes
jec1970
does anyone have the wiring color codes coming into the ignition switch for an early 90,s model Javelin boat?
OBJ
Re: ignition switch wiring codes
What's the year and hp of the engine?
jec1970
1990 johnson 120 hp--the maunual only shows 3 wires going to ignition--there is 7 i disconnected from old ignition--purple, purple/white, 2 black, yellow/red, black/yellow, red/white
OBJ
One black should go to control case ground and the other black to one of the "M" terminal of the switch. The black w/yellow stripe goes to the other "M" terminal.<br /><br />Yellow w/red stripe to the "S" terminal. Start or solenoid.<br /><br />Purple w/white stripe to the "C" terminal...choke.<br /><br />Purple wire goes to the "A" terminal. Ignition terminal....feeds accessories.<br /><br />Red w/white stripe goes to the "B" terminal. Battery.
jec1970
where and what is the control case ground?
jec1970
does it matter which "M" terminal i connect the black and black/yellow wires to?
OBJ
The control box case ground is simply a place to connect grounds....instead of putting all grounds on the ignition switch terminal. Usually, one "M" terminal is a "post" with a screw. The Black w/yellow stripe would go here but it really dosen't matter to which "M" terminal you use. Just keep the black w/yellow stripe by itself on an "M" terminal. The black w/yellow stripe grounds out the power pack to stop the engine. So don't put it with a black (ground) wire.
jec1970
thanks for the help--fixin to go try it out
jec1970
is there another fuse box besides the one behind the steering wheel? i may blown a fuse and all 8 of the fuses in the box i found are ok
OBJ
Check the fuse on the engine. It'll be mounted on the wireing harness....easy to see. Without this fuse, you get no current to the ignition switch.
