Complete Rewire Parts Recommendation
ShawnQ
I recently tore into my rigging tube to replace my steering cable which was almost locked up. <br /><br />While I as at it, I decided to pull all of my old fuel line out and replace it as well.<br /><br />Once I did that, I noticed that the only ugly/old looking stuff remaining was all of my electrical wiring. So, why not replace it as well?<br /><br />I went ahead and pulled out the seperately loomed harness from the engine. It is still in great shape with water tight connections to the gauges and binnacle mount controls/ignition. So, I put that aside.<br /><br />When I got into my accessories wiring, I couldn't figure out why I had so many wires. Currently, my boat has the following accessories:<br /><br />-Red/Green Bow Nav lights (seperate)<br />-rear Whie pole light<br />-Bilge Pump<br />-Depth Finder<br /><br />I must've had 30 seperate wires running through my boat due to the previous owner having trouble and pulling a new wire, then leaving the old one in there. Needless to say, I pulled out any of the wires that weren't being used. Here's what I ended up with:<br /><br />
<br /><br />With all of the loose-ended wires out of my way, I labeled the necessary wires to run my accessories. I then took them all out and plan to replace them anyway.<br /><br />After I had all of the wiring out of the boat, I went ahead and pulled the Fuse Block out of the boat. Should I clean this up and re-use it, or should I just replace it?:<br />
<br /><br />I'm leaning towards replacing it. With that said, here's where part recommendation comes into play.<br /><br />I searched through the mega-mall, and didn't come up with anything that looked quite like it. Any recommendations?<br /><br />Also, my wires are travelling about 15ft. What size wire and fuse should I use for the following objects?<br /><br />-Nav Lights<br />-Bilge Pump<br />-Baitwell Pump (plan to add this)<br />-LED Deck Lights (plan to add these)<br />-Depth Finder<br /><br />Thanks in advance.<br /><br />Shawn
ShawnQ
Re: Complete Rewire Parts Recommendation
Forgot to add:<br /><br />Do they make a fuse panel like this that is water tight?<br /><br />I would like to do this one time...and not have to worry about it again...and I don't want the future owners to worry about it either.<br /><br />I plan to do the wiring and connections correctly (once I figure out how that is...crimp, solder, or both? :eek: )<br /><br />Thanks<br />Shawn
ShawnQ
Other than heat-shrink on all connections, what can I use to make sure the blade connections stay corrosion free?<br /><br />I find it amazing that people spend the time/money to heat shrink all of their wiring, and then leave an open blad connection or ring terminal on the end.<br /><br />SQ
crab bait
bingo..!! exactly..!!<br /><br />i'd clean it up an re-use.. a new one will get that way pronto..<br /><br />get some CRC contact cleaner available everwhere.. spray/soak the snot-out-of-it..<br /><br />then push each fuse in & out many times while spray wet ..<br /> <br />good as new..<br /><br />funny how wires multiply.. :) <br /><br />if'n you use all the same color wire,, say white.. take a 'sharpie' an write on each conductor what it is.. <br /><br />an/or/also,, buy a multi color tape pack at hardware or even 'dollar store' an wrap identifing color wrap at terminated ends.. <br /><br />also right at the mounted fuse block ( say mounted on white substrate ) write on substrate what is as wire leaves fuse block.. also a 'legend' of what the tape colors mean..<br /><br />i'd use marine grade 'tinned' wire..<br /><br />buy all 14 guage..<br />BINGO..!!<br />yes,, there is.. hardware store by a small tube of aluminum wire no-oxidation compound.. put on every mechanical connection.. fuses, spade/sta-cons/push on connectors, trailer bulbs , trailer plug, ect,whatever.. <br /><br />little tube last forever .. an alittle dab is all that's needed..<br /><br />crimp & solder..
ShawnQ
Crab,<br /><br />The black liquid tape is what you talk about to dab on the connections?<br /><br />I tried this on a terminal that my battery switch connects to...and it corroded underneath it...maybe I bought the 'cheap' stuff.<br /><br />Thanks for the help.<br /><br />SQ
crab bait
no,, 'black liquid tape' is an insulator..such as real tape but it's liquid..<br /><br />stuff i say,, is not an insulator but a conductor of electricity.. an keeps connections from the 'greenies'..
CalicoKid
Ideal brand "no-al-ox" is one.<br />Fargolene is another.<br />Gardner Bender brand anti-ox comes in a red tube.<br /><br />Look in the elcctrical dept of a home improvement store.<br />It's a gray greasy compound that coats and protects aluminum conductors and terminations in electrical panel assemblies and the like.
