Rivergator
Thread starter- Joined
- May 7, 2013
- 240
I need your help to clear up a lot of confusion on my part about the power trim system. As you know, I don't know much about my own boat because I never had a chance to drive it since I bought it several years ago, because it was trashed and needed a complete restoration of which I am almost done with. So I have no experience with the way how some of the things on my boat actually work. I am in the process of checking out and testing my power trim system and I have encountered a number of problems already. I know that my entire trim pump cluster works because I overhauled it and bench tested it. That includes the solenoids of course. When I push the up and down trailer button on the shift lever of my remote every thing works fine. When I push the buttons on the helm, nothing works and that as of right now makes sense as I have already found a broken wire behind the dash but don't know where it goes. That's why I need your help especially from Sylvan owners who may have the same dash board control panel as I have. Picture #1 is what I have on my boat but my boat's manual does not show that. What it shows is picture #2. Here is question number one. Looking at picture #2 why are there 3 buttons? I would imagine there is the up button and the drive goes up and there is the down button and the drive goes down. And why are they marked so confusingly? The middle button and the top button say UP and then the middle button and the bottom button say OUT and IN. WTF, why doesn't it say DOWN. I am confused. What am I missing here? Now to picture number #1. There is a big button with an arrow pointing up and I assume when you push that button the drive will go up (but it won't right now because this is the button which has a broken wire). Then underneath is a toggle switch. Now what is that for? If there was another button with an arrow pointing downwards I would assume that is what you push if you want the drive to go down. Once all of these questions have been answered and I understand how this is supposed to work then I guess it will be relatively easy for me to chase and find where the broken wire goes.
