Re: navman fuel sender
Hate to through a kink in your plans but I want to add that you may have a small problem running an extra engine off of the main engine fuel supply. <br />The navman should be set up to remain "on" when the main engine is running. That is a setup option in the navman menu. There should be no way to turn it off while using the main engine or it will give incorrect "remaining fuel" levels. Turn the navman off when the engine is in use and it will have no way of registering fuel usage. Now run the small engine and the main engine's ignition will be off, right? If you remember to manually turn the navman on while using the small engine, you have no problem. If you run the small engine while trolling or fishing, then you most likely will not forget to turn on the navman. <br />The fuel sender unit should be installed after an inline filter. If you "T" off of the main fuel line too close to the main engine, you risk the small engines fuel pump siphoning fuel away from the main engine's supply line. That may or may not cause a problem.<br />You have the right idea. I like the navman's fuel monitor program too. Just wanted to offer some advice from personal experience with the fuel sender unit.
