.<br /><br />Old C. is correct on the first part, but on the last sentence I think he simply forgot to add, that at position BOTH the C will be hot also.<br /><br />Note: if you continue reading the article from Continuous wave above, you'd find some word of caution in leaving the switch on BOTH. Only use it on emergency for starting, when one or both batteries are weak."C" means "common". It's hot any time the switch is not in OFF (assuming two good batteries). Anything connected to "1" or "2" will always be hot, regardless of switch position.<br />
