Clicking Noise From Switch Panel
Hunter 34
Sometimes when I turn on the power switch on my control panel on my Skeeter Bay Pro, I get a consistant clicking sound, and when I adjust the round nob that labeled Min-Max the clicks become faster or slower depending on which way you turn the nob. Is this noise normal? If not what could be causing it. Thanks very much
Re: Clicking Noise From Switch Panel
So what's the knob for that's labeled MIN-MAX? Sounds like it might be a live well timer and that there may be a circuit breaker that's cycling. Does your live well pump system work?
Reel Poor
Hunter that clicking moise is coming from the depthfinder transducer. The knob on the dash controls gain/output power of the unit. Typically found on a Flasher style unit.<br />MAX = Full Gain <br />MIN = Low Gain <br /><br />Usually turning the knob all the way to the left will turn the unit off. Sometimes the on/off part of the switch will fail and someone will hook it up directly.
