Protecting Electrical Wires
dmarkvid2
When running all my main electrical wiring from the battery to my distribution fuse blocks should I run them through plastic conduit?
TTU_Guy
Re: Protecting Electrical Wires
I was thinking about this same question the other day. If you were to run a smooth conduit, wouldn't that be a great way to be able to later easily fish wires from the cockpit to the back for new accessories? Has anyone done this before?
Reel Poor
Manufacturers do this quite often with PVC pipe. Loose wires should be loomed or protected also.
dmarkvid2
Hey R Poor, Thanks for that site. How would I attach it to the boat, using that, or even plastic conduit from homw depot? Thanks, Mark
Reel Poor
This is what I use. The ones with the round top have a hole in them for a screw. The others are for bundeling.<br /><br />I have also used these. Just mount these in the boat with a screw then run a wire tie around the loom then through these mounts to hold it all in place.
poolshark38759
if you use the PVC coduit, get some 1-hole or 2-hole straps (home depot know they are) to moutn the conduit with...
