Re: Bilge Pump Wiring
Actually if you have a dual battery system, you might as well run two bilge pumps, one fwd and one aft. Use a double throw double pole switch. Each pump is on it's own pole. one side of the throw is the manual (pwrd on thru the battery switch) Both poles. The other side is not common; but each pumps float switch wired thru. <br /><br />The fwd ones float switch should be 2-3" higher than aft. The float switches (automatic) should be wired to each battery aand to the auto on the dash switch. I ran the aft, primary pump on my hotel laod deep cycle battery and my fwd pump switch on my starting battery. The aft pump handles most instances. If the boat springs a leak and kills the deep cycle battery, you have another several hours to days to get back to the boat and catch the leak. <br />Why not run the two batteries parellel? Pumps fail, clog, break hses, lose connection...<br />Two is real redundancy.<br />I decided this is best after showing up at a beach party to hear a story of a broken sea valve for a guys wash down pump. He was partying next to the boat 200 yards away as it killed the battery and sank over a six hour period. It never went down, just flooded the engine enough to hurt the wallet.<br />Jus an idea, you guys with better drafting programs can draw up a plan if you agree with my idea.
