When charging battery, do I need to disconect from boat?
Bert1
I am running a combination deepcycle/starting battery on my boat. When I use an external charger, do I need to disconect the battery from the boat? (i.e. power to engine and accessories). Could accessories or the engine alternator be damaged if not disconected? The engine is a 2002 50hp Mercury 4 stroke. Thanks<br />The charger is this unit sold at Cnd Tire. <br /><br /> Motomaster Nautilus 10/2A Battery Charger w/ Microprocessor <br /> <br /> Automatic and manual operation <br />10A fully automatic battery charger with reverse polarity protection <br />10amp charge and 2amp trickle charge feature to maintain batteries during off-season storage <br />Ideal for charging 12V marine starting and deep-cycle batteries
jtexas
Re: When charging battery, do I need to disconect from boat?
nope, just hook it up & plug it in, no problem.
Texasmark
Some folks that manufacture all kinds of stuff suggest that you do it, but I think they are just covering their ..... The battery is such a low impedance, any spikes in the charging system should be absorbed in it and you shouldn't have to worry about "reverse over voltaging" the rectifiers in the engine's charging circuit.<br /><br />Mark
Nearly every electronic device has "in-rush" protection on the input. Your car electronics survive for years without be disconnected for charging, so will your marine electronics.
waterinthefuel
Just don't start the engine while the battery is being charged externally. A new recifier would be in your future.
Bert1
OK folks, thanks for the advice.
