electrical nightmare continues.
bandit86
Banned
I have about a dozen small wires run right to the batteries. most of them I now know what, bilge pumps, fridge, radio memory, but I found one that makes me wonder. The trim power supply goes right to the battery. Without a fuse. Is that a good idea? I'm going to put a 20A fuse inline, think it should be enough, but should I leave it right on the battery?
jtexas
Re: electrical nightmare continues.
Is it a good idea? My tilt isn't fused either - it's an OMC accessory unit sold with the 70hp in 1979 - dealer-installed I believe but the schematic doesn't show a fuse. And it doesn't have a relay - the switch carries all the current. I'm going to leave it be. It's also wired right to the batt.<br /><br />You could try 20A - I'd be tempted to put in a 30A circuit breaker. And I'd definately leave it on the battery.
bandit86
Banned
I moved it up to the common on the battery disconnect, but didnt put a fuse on it. I'm going to look into getting a ground and power bus bar for everything hooked to the battery, maybe run the trims off that
302
Bandit for whats it's worth my tabs had a breaker next to the trim unit tried to reset with negative result. My friend whoes a boat mechanic disconnected the trim swicht from console pulled the wires and found inline circuit breaker reset it back in business. Good luck.
MrBigStuff
Just remember, the job of the fuse is to protect the wiring from burning up in the event of a short or overload. A fuse or breaker rated higher than the wiring is doing no good. I'd measure the draw, add 10% for peak current draw and then check the wiring to insure it's rated for the load. If so, put in an appropriately sized fuse or breaker.
