valleyviewlawns
Thread starter- Joined
- May 2, 2023
- 58
I am troubleshooting a rich condition. Bad enough that it won't idle well, and fouls plugs. I just rebuilt the carb and want to tune it, but I do not know how to hook up the vacuum gauge to get vacuum. This engine only has a large port under the carb that goes to the PCV valve. I will be timing it using the shunt, although the EST timing procedure link in the DIY section goes to an Evinrude post. I think I can get it timed with my manual. Should be initial 1degree, and 18 degrees at 600rpms.
Where are people hooking up for vacuum to adjust the carb?
