vro pump
capebill
Re: vro pump
QUESTION<br /><br />If the oil side diaphram has a "large" hole in it will it pump oil at all<br /><br />there is no suction<br /><br />I had this happen to me last year<br />( engine stopped revving to max level ) would only go to 3900 -- recommended is 5400 - pulled boat machanic said it was a "large hole" in the vro pump oil side diaphram - replaced vro - <br />put baot back in<br />-Did not run right - same symptoms - pulled boat again - turned out to be a pin hole leak in my fuel lines -<br /><br />Johnson said "OH WELL"<br /><br />it cost me $590.00 for the fix with pulling the boat twice - water tests - and then fixing the real problem<br /><br />CAN ANYONE TELL ME WHAT THE COST IS FOR A NEW WATER PUMP in a 2000 johnson hp<br /><br />I have been asking this question and getting no real reply<br /><br />an additional Direct email response is appreciated to capecoralbill@swfla.rr.com<br /> <br />Bill Cape Coral FL
jtc1945
Re: vro pump
Question, why (under normal operation conditions)do you determine that the fuel bulb should be firm ? The bulb is on the suction side of the pump (wich should keep it under negative pressure). Over the last 35 years & a dozen or more new outboards , merc, force & evenrudes, I have never seen a firm fuel bulb unless I pump it manually. While rinning they are usually soft. By the way, my newest is a 2002,175 johnson ( had a new power head installed this year) & the best, most trouble free was the 120 HP force. The worst is my 1999 merc (yamaha)15 Hp, 4 stroke---- go figure--.
buckw3
Re: vro pump
when i pump it it womt even get firm guessing i must have a pin hole somewhere
