valleyviewlawns
Thread starter- Joined
- May 2, 2023
- 58
All 3 plugs on port side bank were fouled this time, soot covered. Starboard side plugs were just a little wet with fuel. Fuel pressure is 6psi at the regulator. Going to pull the carb again and take a look at everything.
1. 146
3. 146
5. 152
2. 146
4. 146
6. 150
Compression test boat, 7/8/2023
1. 146
3. 146
5. 152
2. 146
4. 146
6. 150
I got a question here. I have slack in my secondary linkage. And when I went to replace the diaphragm in the secondary, the one that I pulled out of the carb is a short one, but there is a short and a long in the kit. Do you think the long would take up that slack? I'm wondering if that slack is from having the wrong diaphragm in the carb? When I was trying to set the transfer slots in the secondaries, the throttle plates moved quite a bit, like there is slack in the linkage.That may push your needles open
