Flash Wax Man
Thread starter- Joined
- Jun 24, 2003
- 30
Hey Guys,<br /><br />I have a 1984 Johnson 115 Hp V4 on a 1988 18Ft Angler CC. Just bought the boat. It ran fine on a sea test when purchasing. It still runs fine now, but when I run the motor more than 3000 rpms the warning buzzer sounds and stays on until I throttle down to idle. The motor has the VRO system. I checked the oil and pumped the ball and it was hard. <br />I also see the water tempature gauge climb to about 220 degrees. The engine is not running hot. The pump is pumping great and the water is cool. Felt the heads and they seem at normal temp. My question is, What is that buzzer sounding for? The water temp or the VRO? It only does it when under load over 3000 rpm. Thanks.<br />
<br /> Joe
