should I tune it up or leave it alone
oldblew
hello, I rebuilt the carb on my 72 johnson 9.5 and afterplaying around with the fuel mixture it runs great, in a tank. I planned on replacing points and condensor since I just bought the motor, should I leave it alone since its running fine? also water is circulating good so should I replace the impeller.I do want it to be reliable. I have never messed with a boat motor and the people on this web sight have helped a bunch thanks. Jim
oldblew
Re: should I tune it up or leave it alone
I just got the motor yesterday I was told it ran great and couldnt get it to run tell rebuilding carb
wayne h
go though the engine this way you know what you have. change the points,plugs,condencers,and service the lower unit this way you know what you have.also i would decarb the engine since it has probobly never been done.its better to be safe then sorry
