1972 18HP Evenrude (Power Loss Problem) Please help...
Bigtex
I have a 18hp Fastwin Evinrude and it has lost power between outing that were two weeks apart. Put in new gas/oil and lubed lower unit is the only thing I have done to it different. I noticed that there was a small vacume hose that runs from the frount of the motor to the right side this hose goes from aprox. 3/16 frount to 1/8 right side I have replaced this hose and pocked a wire into and it seems to be clear. Any ideas...PLEASE HELP.jdev@ev1.net
Dhadley
Re: 1972 18HP Evenrude (Power Loss Problem) Please help...
Start with the basics. Check compression and spark. If compression is OK you may just have lost spark on one cylinder and a tune up is all thats needed. What plugs? Fuel? Age of fuel? Linkage OK? Make sure the carb is opening all the way.<br /><br />Good luck!
Bigtex
I have put new points,plugs,and condenser fuel is new compression is over 100 PSI in both cylinder. carb seems to be opening all the way too. Also gap on plugs are 35 too. Anything else that I can check?
Dunk
That 18hp engine was the last year for coils under the flywheel. Where the coils changed when the points were done? If they are the originals and she has sat for awhile it's more than common for the fresh heat to swell them and break the old epoxy on them. Once they soak up mositure they will quit.<br /><br /> If one did quit she running on one cylinder. Get her warmed up so she starts easy then try starting her with one plug wire off. If she starts on one try it with the other one off and the first one back on. You could just pull one off while she's running, but if don't have insulated pliers you'll get nailed.<br /><br /> If I'm wrong about the coils and they are on the engine block there is still a third sensor coil under the flywheel that could be causing the problem. I just sold a 73 20hp and I think I read somewhere it was the first year with the coils on the engine block.<br /><br /> Either way the first thing you need to do is make sure she has spark in both cylinders. You also might want to be a little more specific about how the engine acts.<br /><br /> Yes, replace that hose if it look stiff or dried out. It runs excess lube oil to the main bearings.
Bigtex
I changed out the hose and it seems to do the samething. But it blows water out of the 30 gal. trash can I have not put it back in the water yet to see if that was it or not. And I will try the spark plug thing too. It has no power at WOT. Thanks for the tip.
