1994 Evinrude 48
Mark Champagne
I have a 1994 evinrude 48. i need some suggestions it will start if i chock it with my hand but it'll kill will not idle. I cleaned the carbs. Someone told me they may be the wrong caebs. Does anyone have any suggestions. I sure could use the help<br /> Thanks[*]
clanton
Re: 1994 Evinrude 48
Do the carbs have number on them? Does overheat horn work?
Mark Champagne
No the overheat alarm does'nt work. It don't run long enough to get hot.<br /> The numbers on the carbs are 432986<br /> mx<br /> 0 F N<br /> Thanks any help is apprec.
clanton
What is model number of engine, and does carbuator have black plastic top?
Mark Champagne
The model number is E48E9LCER it's hard to but i think thats it.<br />Theres no black plastic on top of carbs.<br /> Thanks for trying to help
clanton
It is a 1989 engine and looks like the correct carbuator. Check roller in linkage that has a long curved slot, roller should have clear plastic sleeve, if sleeve is missing idle and advanced timing will be off. When I clean a carb,I use a strand of copper wire to clear all passages, when you are sure that carbs are clean and floats set, do a link and sync, dont skip any steps. Check plastic cap on fuel pump for splits, and bad orings, there is update kit for this.
Mark Champagne
Thanks for the help. I cleaned the low idle jets with a wire it idles great.<br />thanks again for your help
petryshyn
clanton is a man of few words.........but when he speaks, he is always right on!!!<br /> :)
Whaler15SS
I have a 1988 Johnson 48 SPL with a poor idle. After reading this thread, I checked the "roller in linkage that has a long curved slot, roller should have clear plastic sleeve, if sleeve is missing idle and advanced timing will be off." <br /><br />In my case, the clear plastic sleeve has broken into two pieces, half of which is sitting in the engine pan and the other half still clinging to the cam follower. Question: Where can I get a new plastic sleeve or what parts do I have to get to get a new plastic sleeve?
clanton
The roller and sleeve come as one part, dealer item.
clanton
The roller and sleeve come as one part, dealer item. Cant locate part number, I did a quick search. What is model number of your engine?
Whaler15SS
J48ESLCCC. Is the sync cam supposed to be mounted loosely, i.e., a fair amount of play side to side?
clanton
The 1988 48hp parts list does not show the curved linkage with slot. The pn for a 1989 48hp is 432572 and the roller on the carbuator arm is 397499. You should verify these numbers with dealer that has current manuals and bulletins. Your engine may be a late production model and have 1989 linkage.
Whaler15SS
Thanks. Looking at a 1990 exploded diagram, the part I'm referring to is called a "throttle cam". The lower carburator has an arm with a cam follower that has a roller with a clear plastic sleeve. That clear plastic sleeve is what cracked in half. The throttle cam seems to be very loosely mounted (lots of side to side play). Is that normal?
