I'm having cooling problems with a 1984 40HP Evinrude. I have good flow out the telltale, but I get barely a trickle out the prop hub, and if I run the motor at just above idle for more than 10 minutes, the temperature alarm will go off. I've changed the thermostat, but this didn't correct the problem. I currently have the lower unit off to change the water pump. I'm wondering if I could have some salt blockage in the water channels in the block. Can I safely hook a water hose to my water tube and try to flush the system out? I'd do it, but since the thermostat would be closed, I'm wondering where the water would go out. Maybe the pressure relief valve would take care of this?
