I have a 98 Evinrude 250 (carb) and would like to test the compression on it. I bought a kit, that has the gauge, a rubber bung, and two sizes of screw-in adapters that would go where the sparkplugs were. <br />Should I run the engine before testing? I've also heard about spraying some WD-40 in the cylinders.. And where would I put the spark plug wires to avoid any personal injury/damage to the motor? Do I turn it over WITH the fuel lines connected or not (i'm assuming leaving the fuel line connected may start it up, or remove all the plug wires?) Are all the plugs removed at once, or one at a time for testing?<br /><br />Any step by step guide will be of great help.<br /><br />I'm also investigating why the output of this 250 is rated (printed on label) at 167KW~223 HP
, So if anyone who knows about these Evinrude/Johnson engines can shine some light.. I've called Evinrude and the rep didnt have the slightest idea what i was talking about... so I'll call again and hopefully get one who knows his stuff.
