Hello everyone,
I have a 1969 Johnson V4 with 115hp.
It has the hydro electric shift.
The engine runs great and has all the power to propel my boat forward.
The gearbox doesn't like reserve though. It keeps stripping the gear selector teeth.
I replaced the axle and gears twice, got new seals, redone the wiring and made sure the switch is working correctly. I am using the correct hydro shift oil. Yet when I fix everything she will go in reverse a couple of times and then, the gears are grinding again. Neutral is working fine.
What could be a possible cause of this problem? A bad hydro pump?
And will this engine block fit on a non electric shift gearcase?
Any help is much appreciated.
![WP_20240115_16_40_43_Pro[1].jpg WP_20240115_16_40_43_Pro[1].jpg](https://forums.iboats.com/data/attachments/393/393552-27ca3f6e0d2140ae6f0589ed39f80a8a.jpg)
