Re: Hydro-Electric Lube Question?
Well guys, I did it, I have gritted my teeth, dropped the leg, and pulled of the soleniod cover.<br /><br />One of the wires leading down to the bottom soleniod was mostly broken just under the cover, so thats one thing to fix, I have lifted the whole assembly out, cleaned the lot up and gave the plunger and the outside of the soleniods and both shafts a quick buff with some really fine emery paper.<br /><br />it all seems ok.. I can't find anything wrong, putting power to one of the wires while earthing the body of the unit does indeed result in it becoming magnetic, ditto with the other.. so they are all right.<br /><br />with everything clean and smooth, I figure its time to replace the wires that were damaged, and install the lot back in again.<br /><br />Or have I forgotten something? (for example, where is this diode people keep speaking of?)<br />Also, do I have to strip the foot to clean the pump screen?)<br /><br />Just as a description for those who haven't done this and want to, there are 4 bolts holding the cover on, remove them, then lift the cover up, the two wires connect to to round cylenders, (the soleniods) which sit in an upright cutout tube running down into the gearcase. (don't lose the spring clip sitting on top of the top solenid between it and the cover.)<br /><br />gently lifting the cover and wires and the whole assembly will come out more or less as one piece..<br /><br />the two soleniods sit on top of each other. the bottom one has a tube of around 15cm or 6.8 inchs length) fixed to the bottom of it. (although it is fixed, it can slide about 5 ml in and out, but it can't slide out completely.)<br />running through both soleniods is a little piston or plunger attached to a long straight thin shaft. 22cm or 10 inchs long. that plunger fits into a recess in the top of the top plunger and the shaft on the plunger fits right down through both soleniods and the tube on the bottom one.<br />Here is a piccy I just made of it, very rough, but it serves its purpose.<br />hope it helps someone.<br /><br />rgds<br /><br />Franki<br /><br />
