Re: Idle speed 1993 Evinrude 115 HP
Setting idle speed requires the adjustment be made in the water, boat unrestrained (not tied to dock) and with the correct prop installed. Kiwi is correct, idle speed should be 600 to 700 rpm and that's in gear. If you try to set your outboards idle speed while running on a flushing attachment in your driveway (and I don't know if you are or not), you will encounter problems when you launch the boat and try and run it in the water. The engine requires the back-pressure from the column of water that's in the mid-section when the boat is at rest in the water.<br /><br />QuickStart is activated every time the engine is started (yellow/red wire from keyswitch, to solenoid, to powerpack). The powerpack or timerbase (depending on model) have electronic circuitry that advances engine timing 10 degrees. Depending on the engine model, QuickStart deactivates when the engine reaches approximately 96 to 105 degrees(F) (white/black wire from temp switch grounds circuit when correct engine temp is achieved). When restarting a warm engine, it "time-outs" after 5 to 7 seconds. Also, it goes inactive above 1100 rpm's.<br /><br />So just what kind of problem ARE you having??<br /><br />-John
