warning horn
bigblock
150 johnson engine warning horn goes beep beep beep continually in speed with engine rpm.null
wippb
Re: warning horn
Hi Big block<br />Try posting the year as well so the guys here can narrow down the problem.<br />Good Luck
bigblock
Re: warning horn
is all i need to do to the vro is unbolt the vro bracket and remove oil line; run fuel line from the filter to the carbs? what is the oil to gas mixing ratio? how do you check the vro?
Trent
Re: warning horn
50:1 oil/gas mix<br /><br />If their is oil in your oil tank..Disconnect the wires going into it and see if the horn stops beeping. Could be a bad sensor.
seahorse5
Re: warning horn
If the beeping changes frequency with the motor rpm, you may have a charging problem (AC leaking into the DC system), or a faulty oil level sensor in the tank. If the horn has been replaced with the one that beeps when you turn the key on, that could be suspect also.
