I have an electrical problem on a 28hp johnson(1991)that prevents it from starting. The starter motor will not run when key is turned. When i turn the key i get an audible click in the solonoid. At first i thought the starter might be bad so i hooked up a portable battery pack directly to the starter and it fired up fine with no hesitation. Then i thought it has to be the solonoid, so i replaced that and still have the same problem. Can the problem have something to do with the starter switch or nuetral safety switch? I dont know much about the wiring in the switches and not sure how to check to see if this is cause of the problem.<br />thanks<br />james
